I need some replies from you guys who have had experienced the stalling issue due to a bad FSD. I, too, am having the stalling problem now. My pump was replaced at 90K miles, but I now have 155K. The problem just started this week. I replaced my lift pump already. It stalled again this morning. I have noticed that it does not matter whether I am accelerating or just parked in the parking lot, it can stall. It always starts right back up with no extra cranking. However, when the engine is good and warmed up, it does not stall. Only on short trips around town does it happen. No light comes on for check engine. I went to a mechanic today and paid to have him to check for history codes, and his scanner said there were no codes to report at all. I did notice that the fuel shut off solenoid (silver tube you can put your hand on in front of the injection pump) seems a bit loose; not a lot, just a little bit -- is that normal? You can toggle it a bit with your finger on the top hex bolt. Should I replace the PMD? Please help guys. This is a lot of money so I need to make sure I fix the right thing. Thanks.
Adam
'98 GMC K1500 4X4 extracab 3.42 gears SSdieselsupply heatsink/ FSD, JK 3.5" exhaust w/Allied "Quiet" muffler. JK Boost controller. ISSPRO pyrometer and boost gauges. '79 Cadillac Eldorado Biarritz w/ 5.7L "Mr. Goodwrench" Diesel. All stock except: Racor fuel filter/separator and Delco #60G glow plugs (ground-down to make them fit). '83 Suburban with 6.2L Diesel and "Greasecar" fuel kit. '91 Mercedes 350SD with 3.5L 6 cyl turbodiesel (wife's car--best car I have ever owned). HaHa-I-love-dem-all!
