Results 1 to 20 of 28
Thread: All diesel fuel treatment users.....?
    Maverick Guest
    Question
    Just taking a poll here......
    Has anyone using any brand of diesel fuel treatment/conditioner had any injector or injector pump problems? Please reply only if you have been using the additive for at least 75% of the vehicles mileage. Please reply if you have had problems or have not. What brand? Trying to see if I can find a pattern if treatment really helps the fuel system.
    [ 11-08-2002: Message edited by: Maverick ]</p>
    Oct 2002
    Long Island NY
    I have had a 1980 1500, 1982,1992,1998,all diesels,and presently own 2002 DM. Have always used Stanadyne Perf. Formula and never replaced any injectos or pumps. All vehicles were kept well past 100,000 miles. My dealership always recommended it and still does. This is a truck only dealer and I think most people with diesel related problems come from car orientated dealerships that are not used to dealing with this type of equipment.
    \'02 3500 SLT D/A, vanAaken Smart Box E, Kennedy 4\" exhaust, Amzoil filter, Delvac 1, 34\' Carriage LS, Pullrite hitch, 225/70Rx19.5, Trailair Fifthwheel pin box.
    jbplock Guest
    I had an 85 VW Golf Diesel that I purchased new. Sold it about a year ago with 180kmi. Never had a problem with the injection system. I always added PowerService to the fuel and changed the filter every year.
    In my 98 6.5 I ran Power Service then switched to Standyne Performance formula and a dash of two-cycyle oil (after joining this page in 99). Just sold it with 65kmiles with original pump, PMD and injectors. Never had a single problem with driveability. One thing I also do is never let the fuel level drop below
    Apr 2002
    Willow Springs, NC
    Cool
    Howe's every tank for 25,000+ miles, no problems or signs of problems .... same run in farm tractors for untold numbers of hours, never had an injector problem.... Jim
    \'02 3500 CC HD 4X4 LT D/A, Charcoal Gray Metallic,Juice 4.61, Loaded from end to end and most places in between
    imported_ Guest
    Stanadyne perf formula every tank...no problems to date
    Apr 2002
    calgary ab.
    Smile
    Mad Max
    Where you buying that product in Canada?
    thanks
    [img]smile.gif[/img]
    2003 SLT Duramax CC/SB Carbon Metalic, Juice\'d, JK Light harness, HD sprayed box liner, J&J Millennium running boards, Fumoto valve, Tekonsha Prodigy brake controller, TFP Stainless door handle inserts, Michelin LT265/75R/16, combination Tool Box & Fuel tank(165L) with timed transfer flow, 2 Micron CAT Primery fuel filter, dndstarr@shaw.ca<p>PIC\"S <a href=\"http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax\" target=\"_blank\">http://photos.yahoo.com/bc/hx30/lst?.dir=/duramax</a>
    La Verne, CA
    I have been running FPPF Total Power since new and the truck now has 20K. No problems so far.
    02 Chev 2500HD D/A 2WD C/C S/B White/Graphite LS/Juice/KD Exh/Gauges/Mag-HyTek Diff Cvr<br />FB2600 Weekend Warrior<br /><a href=\"http://home.earthlink.net/~k-tuttle/\" target=\"_blank\">Various Pics</a><br /><a href=\"http://home.earthlink.net/~oildealer\" target=\"_blank\">Amsoil Products</a>
    Jun 2002
    Reno
    Maverick,
    I'm using Redline Racing 85+ with every fill up. No problems
    <b>
    Nov 2001
    Evansville, IN / Melbourne, FL, USA
    I have 17,000+ miles on my 2002 DA 2500HD. I started using Howes Meaner Power Cleaner in every tank at about 2000 miles. Product states that it contains no alcohol and is rated "superior" by Cummins L-10 test specifications. I buy it at Flying J for about $10 per quart. Use one oz. per 8 gal. of fuel. To date, my average speed on truck is 45.5 MPH and average MPG is 17.6 including some towing and some town driving. I am pleased with the Howes product and have experienced no engine related problems with my truck.
    I realize that 17,000+ trouble free miles is nothing to brag about. We can brag when we hit 200,000+ miles without a problem.
    2002; GMC; 2500HD; D/A; extended cab; long box; 4 WD; Summit White; cloth buckets; ONKI running boards, Sierra mud flaps, A.R.E. Z-Series topper, Bed Rug, Fumoto Oil Drain Valve, and McKesh towing mirrors.
    Southern Minnesota
    28,000 miles, Stanadyne "Blue" for the first 4,000 miles, FPPF Total Power since.
    When I'm NOT using fuel additive, my trucks does the lope thing (RPCV bad- 10-00 engine build date, early pump). As soon as I add additive, the lope dissappears.
    Otherwise, ZERO problems. If I can only get my SM to change out my RPCV, everything will be peachy in DMaxland. [img]smile.gif[/img]
    2003 Chevy 2500HD LT EC/SB D/A <br />Dark Gray, loaded..<br />Kennedy 4\" Exhaust, Headlight Harness, Access, Air Lift, Luverne, <br />Hot Juice, Mega Filter, more....<a href=\"http://community.webshots.com/user/somndmax\" target=\"_blank\">Pics</a><br /><a href=\"mailto:somndmax@yahoo.com\">somndmax@yahoo. com</a>
    Jul 2002
    illinois
    Thumbs up
    I use Archer Soyguard.. [img]smile.gif[/img]
    2002 GMC...Dmax in Black of course..X-cab 4 by 4..<br />Goodmark Cowl Inducton Hood<br />Lund Screen front<br />Stainless nerf Bars<br />aux tank<br />Jardine 4\" Exhaust<br />and some more stuff
    Maverick Guest
    The reason for this question is I had an injector replaced at 98K on my 01' 3500. The signs of this was a blueish smoke from the exhaust. I have now noticed some more heavy exhaust. No real color or anything yet. I am almost at 107,000 now. Yesterday I topped off and dumped a bottle of Standyne One Shot Performance Formula. It treats 30 gals. I have never used any treatment before this. I can honestly say it did run smoother and pick-up on the throttle was faster. Don't really know if my exhaust cleared up with it becausr I burned up 50 gals of fuel that day. I know where I can buy Standyne locally but know nothing about this Total Power. How much is this compared to the S brand?
    Nov 2001
    mississauga ontario canada
    Have used FPPF since new put it in every fll up have 23000Km = 14000miles every thing OK COST IN CANADA $15 each for a case of 12 Stanadyne $23 for 1. As posted previously I cut the filter in half bottom half was dirty black top half was discolored white.
    you must have bought a watered down version of the product (no pun intended) but the one bottle of either product is good for 250 gallons not one tank full, based on articals I have read too much additive is not good.
    good luck
    GMC 2002 DURAMAX, SLT, EXCAB SHORT BOX 2500HD, 4X4, AUTO
    ACCESS TONNEAU COVER, 3" STAINLESS TUBE STEPS
    JORDAN BRAKE CONTROLLER
    34ft 10,000 lb TRAILER, 50 GAL TRANSFERE FLOW TANK (total 76 gals)
    Cortland, OH USA
    Talking
    Another vote for Howes. I have 52500 on my 2001 with no fuel or injector problems. Howes will also pay the tow if your fuel gels. They also claim there is no problem if you use too much.
    2001 XCab LB 4WD D/A, Linex, <br />Roadmaster suspension, Hella horns, <br />ARE cap, Hayes running boards, Fumoto Valve
    Maverick Guest
    Letsgo,
    If you go to this link- http://www.mwfi.com/descript_perf_form.htm -you will see the ONE SHOT bottle listed as an 8oz. 30gal treatment. I will assume you didn't know about this size bottle and you were refering to the 1/2 gal size which treats 240 gals. Also in the notes at the bottom of the page this is said-"All Stanadyne Diesel Fuel Additives can be blended with each other and "double-dosing" is not damaging - although it may not provide twice the benefit."
    Mudflap,
    Do you notice any difference performance wise as to how the Howes breaks up water and runs it through the system to be burned?
    Nov 2001
    The quart bottle stands and 250 gal is what each will treat, it is set up for the truckers, have never seen 1/2 gallon containers, I saw some 4 oz NO NAME bottles at a place called Canadian Tire $5 each, There is a product called Kleen Flow , it has no centain and when I last looked they did not print product%%% on any literature BUT they have a good sales pitch.
    I might add there are a few manufacturing webs that state you can upset the diesel fuel make up by adding fuel additives.
    The "8 percent" increase in fuel milage is incorrect, It should read the bottle content is 8 centain, the two manufacturers state gas milage should increase, but have reservations.
    Good Luck
    [ 11-12-2002: Message edited by: letsgo ]</p>
    imported_ Guest
    Cool
    ccds/letsgo
    i buy my stanadyne from kootenay fuel injection in Cranbrook..... for 20.00 cash (no reciept) i get 2 bottles of the stuff..... enough for 6 tanks (128 liters)....it might be psychological but my truck seems to run well when i use this product
    Jun 2002
    RUNAWAY BAY, TEXAS
    I too use the howe's injector cleaner, Have 20000
    trouble free miles. I to use it about every 3rd fill-up and seem to get a little better performance for that tank of fuel. The reason i use it is it worked well in my peterbilt trucks. 3500000 on my 96 and 458000 on my 99, never had injector problems, but ran the new cat 2 micron filters since the day they came out...
    2004.5 LLY CREW CAB 4X4 SLT<br />BLACK IN COLOR<br />PRODIGY BRAKE CONTROLLER<br />XM RADIO OPTION<br />FULLY LOADED BUT NO DVD OR ROOF LIGHTS<br />6\" FLAT OVAL WESTIN NERF BARS(BLK)<br />24\' ENCLOSED HARLEY HAULER<br />2003 HERITAGE SOFTAIL CLASSIC<br />265/75R/16 BFG\'S ALL TERRAINS
    Feb 2002
    Boerne, TX
    Been using LUCAS for 30,000 miles at about 60% of the time. No problems, but usually can only find it at truck stops.
    Jomar
    2002 Chevy D/A LT 4x4 EC LB Indigo Blue
    Ranch Hand Grille Guard
    Stock Air Filter Rancho 9000 Shocks
    Luverne STS Boards
    Bestop Electric Towing Mirrors
    Husky Floor Mats
    Reese 16K 5er Hitch
    Amsoil all the way
    Dynomax 4in. exhaust system
    Egt & Boost Gauges
    OD Lockout
    Swiss cheese airbox
    Boothwyn, Pa. USA
    FPPF...
    It says on the bottle "Winter Fuel Treatment"
    Is this something you can use in the summer too?
