Jeff, I guess I'd try testing the pressure cap. Sounds like it's malfunctioning, and not allowing the system to vent as it should. Some vacuum build up is normal due to expansion and contraction within the system, and the cap should be able to vent this pressure.
While pressure testing the cap, I would also test the system to see if it will hold pressure for an extended period of time. You may have a waterpump or a hose leaking you may not be able to see. Has the engine oil level stayed consistant? Any milky crud in there?
Any dealer or reputable repair shop (if they have them in AK ) should have the proper equipment to test the system.
2003 Chevy 2500HD LT EC/SB D/A <br />Dark Gray, loaded..<br />Kennedy 4\" Exhaust, Headlight Harness, Access, Air Lift, Luverne, <br />Hot Juice, Mega Filter, more....<a href=\"http://community.webshots.com/user/somndmax\" target=\"_blank\">Pics</a><br /><a href=\"mailto:somndmax@yahoo.com\">somndmax@yahoo. com</a>
