Results 1 to 8 of 8
Thread: Initial experiences with a 5500 4x4
    ksss Guest
    I finally have my 5500 set up and working. Here are some initial impressions
    Positive: rock solid chassis. Handles fifth wheel loads very well. Great visibility, and the turning radius is also great. Great truck for a business because it looks so impressive. I tricked mine out with large decals etc. Gets a lot of looks.
    Negative: I was worried about not enough power ( based on the 520/300 hp rating and unfortunately I was right. Pulling approx. 17K it really struggles. I have purchased a programmer from Pacific Performance Engineering. Should have it installed as soon as I get a install guide that is 5500 specific. I hope that I can fix the power problem. Next and equally upsetting is the fuel mileage. So far I am getting 7.5 MPG. The programmer claims 3-5 mpg increase. I guess we will see. The 7.5 mileage is pulling approximately 10K. I went on job yesterday that was approx. 120 miles round trip and I used 1/2 a 40 gal. tank. I have yet to refuel to check the mileage on that one. My 01 K3500 has more power and gets better mileage. There are a lot of rattles. The steering takes some getting used to.
    If I can get the power increased and get to atleast 10 mpg I will be happy. Right now I can't say that I am all that excited about the truck. I will continue to post updates especially after I have spent some time with the programmer enhanced truck.
    What did you find out on the progammer etc....
    ksss Guest
    The programmer has helped the power issue. It has taken at least some of the turbo lag out. I have yet to check the mileage. I have not had a fair comparison yet. Or I am afraid I am still getting less than 10 mpg. I set the programmer on the first stage which is 60 hp. I intend to put gauges in the truck and then I will step it up to the next level.
    Any idea why GM does not offer any other gearing in their 4 wheel drive models? I have driven one and the rpms are quite high when running 65 to 70.
    ksss Guest
    I don't know. Running at 65 mph is about 2500 rpm which is why (I suspect) my mileage sucks. I read other guys getting mid teens with these trucks (2X4). I seem to be the only one that feels they are underpowered (gathered from other forums). Maybe mine is a dog or I am the only one who is really pulling with it. They certainly would really benefit from the 6 speed auto. At least when empty you could squeeze some mileage out of it.
    ksss Guest
    I checked the mileage unloaded. Made a 30 mile round trip 55-65 mph and got 13.50 mpg. Loaded With a heavy weight of about 18K (trailer and equipment combined weight) with a light weight of 10K, some stop and go driving 7.5 mpg with 280 miles range on a 40 gal. tank. When I brought the truck home I got around 7 unloaded (actually it was bare back). So between the engine breaking in and the programmer that has improved. Still towing and getting 7.5 is mighty poor.
    Aug 2003
    Jamesport MO
    Give it some time the duramax is barely broke in at 10000 miles. Just my 2cts
    Jul 2005
    california
    I know what you mean about a little slugish on power. Just picked up a 4500 4x4. I pull a 42ft gooseneck trailer. Put the same programmer with snow performance water/methanol kit on it and it has ALOT more power now. But I also really hate cruising at almost 3000rpm at 75-80mph!
