When my head gasket went, the head was still sealed but I was pressurizing the cooling system. Hence I was losing all of my fluid from the overflow. When they rebuilt my block they had to tank both heads, replace sleeve and build up the block and plane it. What a mess!!!
Good luck!!
Bbudus
94' GMC K2500HD, Heath chip, -1.94, Turbo-Master, AFE Cold Air Intake, Bosch High Flow Injectors, 3" Exhaust all the way back, 4.5" chrome tip(exhaust sounds sweet), Heath Turbo Down Pipe, Heath Crossover, IssPro gauges, Three Pod Piller, 98' Cooling Mods, DMax Fan, High output water pump, DSG Oil Cooler, Heath PMD kit, Light kit with high output bulbs(very bright...finally)
