It took me three hours to install the ATS OEM 90 inch running boards on my truck today.
Being a crew cab, it needs four brackets to hold it in place. The front two brackets on either side go into the factory locations and easily bolt in with an 8 mm bolt.
The rear two brackets require one to drill holes in the stubs next to the pinch weld slots. This of course is not a biggie, BUT then you have to use self tapping screws (two per bracket) to screw the top of the bracket to the chassis.
Well, the two of the supplied self tapping screws tapped themselves out of the hole they tapped. I even pre-drilled a tiny hole to start the screws. I should have known better and used a regular sheetmetal screw, but I didn't and followed instructions (know better than that).
Any how, after two trips to the hardware store, I managed to get all of the screws in there and the running boards once installed, look good.
If you do decide to install running boards, throw away the self tapping screws, pre-drill a 1/8th inch hole and then use a 1/4inch or #14 sheet metal hex-head screw. Avoid the frustration. Also a right angle drill also helps.
I figure if the running board fall out, I can always install nerf bars.
A neat trick (which I thought of too late): Spray paint the brackets to match body color before installing and use touch up paint to paint the screws and bolts to match the body color. I also used some rubber undercoating spray to coat the inner surfaces of the brackets. I don't really need to worry about rust in N. CA, but at least it matches the black of the truck.
Bora
2002 2500 HD Duramax Diesel Crew Cab Short box 4x4<br /><br />OEM Running Boards, Hidden Hitch front end hitch, step covers, and driven like there is an egg under the gas pedal
