I run the Hill 4 wd cams on my 3500 and the rake is almost gone. I'd say I got close to 3" of lift compared to maybe 2" from the stock cams cranked 8 turns.
At 3" of lift, the alignment shop had to adjust the caster/camber adjustment bolts a lot (one of them to the end of the adjustment range), but everything is within spec and the truck rides great.
\'02 Pewter 3500 LT CC LB 4x4 D/A G80<br /><br />Predator v1.11, Warn M15000, BFG 235-85-16 ATs, Crimestopper Remote Start, 2.5\" Front Leveling Cams, Prodigy Brake Controller, Nasta Nerf Bars, UNI Foam Air Filter, Fumoto Valve
