The high pressure oil pump is mounted in the engine "V"(where a injector pump would be on a 6.5L). Dr. Performance may be messing with the high pressure oil pump to gain performance. Higher oil pressure in the HEUI injector means higher fuel injection pressure. Lot of PSD owners are buying 10k resistor and bumping up the oil pressure of that pump. It is said that the 10k resistor mod is worth 50hp alone.
hope this helps
Jeremy
PS: Pump failures are extreemely rare, and with 4 of them going out, I be looking at Dr. Performance for answers.
[ 04-10-2002: Message edited by: Jeremy ]</p>
00 F350 CC Lariat PSD 4x4 DAC3 12-speed(US Gear OD) 3.73, Diablo 78, 4\" exh, AD 2X propane 392hp/833lb-ft...01 F250 CC Lariat PSD 4x4 PMT2 auto 70hp SC....83 F250 4x4 6.9IDI 4-speed
