OK, got my gauges, etc. Trying to figure out if my Tap and Die set is gonna work, but doesn't look like it.
What are the thread - TAP - sizes I need for the 1) Tranny temp sender, and
2) the Pyro sender unit?
A Thought - Tranny temp _ I may go with the cooler line to the Radiator. Do I cut and splice into that line to install a T fitting? Flare's required on the lines?
Alternate - since it doesn't fit the 2WD drain plug - I may take that pan back and look for an after-market Drain plug - if the stinking sender will thread up ( I did get 3 adapter's with the sender.. ) Anybody need a 2WD pan? Seems they're scarce!
Wanna have my Stuff together before I crack it open and am Screwed... Thanks
