Results 1 to 10 of 10
Thread: Saw my first G2 Power Stroke run today.
    LanduytG Guest
    Well I guess they have been having a few of these running for a month or so now on the test stands. I just heard about it late last week. Funning looking engine, and it looks like with all the bolt together peices that oil leaks are going to happen. It is quite but I don't think quiter than a Dmax. Wish I could take pictures to show you all. Of course I will keep you all posted.
    Greg
    greg@lubespecialist.com
    www.lubespecialist.com
    1-888-306-4255
    Greg A. Landuyt
    99 VW Beetle TDI
    Stock for now.
    95 K2500 6.5TD
    Phazer,ATS Exhaust,JK Inter Cooler,Gear Vendors, Cooling Mod, Espar Diesel Fired Engine Heater, FSD Cooler, Power Shot 2000, JK Head Light Booster, Amsoil Dual By-Pas Filter, Amsoil Fluids and Grease
    YZF1R Guest
    Thanks for the info. Greg. I was wondering where you've been. Hav'nt heard from you a while on the forum!
    '02 2500HD SLE EC/LB 4X4 Duramax/Allison
    Aug 2000
    Salina, KS, USA
    Here is a picture I found of the G2 PSD. Can't really see all that much though...
    LanduytG,
    Where did you see the G2 running? Did you hear it running?
    Jan 2002
    Overland Park, KS
    Here is some more info. Should be a pretty good engine, but its in a Ford
    http://www.bonforums.com/powertrain/...erstroke60.htm
    Boothwyn, Pa. USA
    ford2chevy,
    Did you notice how old that article is? It has a few mistakes.
    One, the 7.3 is not a Ford engine.
    Two, the G2 will not be camless.
    Mike DP Member #2429
    2001 2500HD GMC Duramax/Allison Summit White CC/SB Loaded
    Amsoil Air Filter, Straight Piped PIC
    PS2K Propane, 22 Gal. LP Tank PIC
    Allison Deep Pan, Transynd Syn ATF PIC
    SPA DG-111 Boost/EGT PIC, Nordskog Fuel Level, High Idle Switch PIC
    VentShades, Husky Mudflaps, 255/85-R16 Dunlop Radial Rover RV's PIC
    Mag-Hytek Rear Dif Cover on the way.. PIC
    Kennedy Headlight Booster Kit TRUCK PICTURES CLICK HERE
    1994 K1500 Blazer 350 Loaded, Flowmaster duals
    LanduytG Guest
    MadMaxx
    I heard it run here in the plant. They ran a few in quality audit. Do not know how long they ran any though.
    Greg
    1-888-306-4255
    Greg A. Landuyt
    99 VW Beetle TDI
    Stock for now.
    95 K2500 6.5TD
    Jan 2002
    Overland Park, KS
    Not I didn't notice how old the article was. Its the only info I could find. The new engine isn't Ford either is it? Its Navistar/International.
    LanduytG,
    Was this at Indianapolis? How did you get to see this engine running? Do they give tours where you can see it running?
    LanduytG Guest
    I saw it at work in the Indy Plant. Yesterday that brought in the Ford Excursion with a G2 in it. I have to say that its quite, buut fact still remains that its in a Ford.
    Greg
    1-888-306-4255
    Greg A. Landuyt
    99 VW Beetle TDI
    Stock for now.
    95 K2500 6.5TD
