I checked the 10 amp fuse and it looks ok. I did not check the relay.
I have been overriding the DRL's at times by pushing the dome override button 4 times but the DRL's used to come back on after the truck was shut off and then restarted. No more.
Now when the truck is started it looks like regular night time lights are on even tho the dashboard lighting switch is off.
Guess I'll head off to the dealer unless someone can set me straight beforehand.
Thank you
\'02 Silverado 3500,LB,CC,4x4,D/A,Stock.<br />Carries an Arctic Fox 11.5\' camper
