Hi,
I was reading past posts about Dually Trucks in the snow and some people mentioned seeing Dually Trucks with only one wheel on each side in the winter. Do I just undo the nuts, take the tire off and put them back on? Do I leave the spacer on? Or how do I do it? Would any harm come from having it as a SRW?
Any other idea's for improving it in the snow? (Kind of wish I bought a 2500HD instead) Would better tires work as I currently have the stock ones?
The truck is working great, but in the snow I have to put it into 4 wheel drive otherwise the back tires ride on the snow and they spin. I have a bed full of snow which would not be that much weight. Would adding 300? 400? pounds help? If so what is cheap to use as weight?
Thank you for your time.
Sheldon
2001 3500 Duramax Crew Cab Long box
