Thread: Oil By-Pass,
    Mar 2002
    Michigan
    Is there anyone out there that has put on a oil by-pass system ? How is it done and will it do the needed cleaning of the oil ?
    Nov 2001
    Eastern Sierra, CA. USA
    Do a search of the forum for dual remote oil filters. You will find plenty of info.
    I have installed the system, it's fairly easy. I had lot's of leaks in mine until I tightened everything. Good luck.
    2K2 Silverado 3500 LT 4x4 Duramax/Allison Crew Cab Loaded Pewter Owner since 01-05-02<br />JL Audio AMPS And SPEAKERS /3x10\" Subwoofer & hundreds of watts<br />Amsoil synthetic fluids<br />Amsoil Dual Remote oil filter<br />Pryo 2001 dual EGT guage<br />Kennedy light harrness plus lights<br />4\" exhaust<br />RS9000\'s<br />Etrex Legend GPS trip computer
    Feb 2001
    Sterling Hts. Mi
    I have the Amsoil Dual Remote on my truck and the install was very easy. Where in Michigan do you live? I'm in Sterling Hts.
    2001 GMC 2WD 2500 HD D/A CC Long Bed 6500 lbs.<br /><b><a href=\"http://www.airliftcompany.com/superduty.htm\" target=\"_blank\">AirLift Superlifts</a></b> , <b><a href=\"http://www.lucerix.com/xmount.htm\" target=\"_blank\">Lucerix Mirrors</a></b><br /><b><a href=\"http://www.fumotovalve.com/merchant.cfm?id=88&step=2\" target=\"_blank\">Fumoto Drain Valve</a></b> , Delvac 1<br /><b><a href=\"http://www.pecuniary.com/synthetics/bypass/dualremote.html\" target=\"_blank\">Amsoil Dual Remote Oil Filter</a></b><br /><b><a href=\"http://www.campingworld.com/browse/skus/index.cfm?skunum=18009&src=SRCH&tcode=37\" target=\"_blank\">Chieftain Air Horns</a></b><br /><b><a href=\"http://www.duallydepot.com/\" target=\"_blank\">53 Gal Fuel Tank Toolbox Combo</a></b><br /><b><a href=\"http://www.dtacorp.com/index.htm\" target=\"_blank\">DTA Running Boards</a></b><br /><b><a href=\"http://www.dakotadigital.com/index.cfm\" target=\"_blank\">Dakota Digital Gauges</a></b><p><b><a href=\"http://www.sunnybrookrv.com/\" target=\"_blank\">2001 Sunnybrook 31ft. BWFS</a></b><br /><b><a href=\"http://www.precisiontemp.com/RV-500Page1.html\" target=\"_blank\">Precision Temp Tankless Water Heater</a></b><br /><b><a href=\"http://www.fortunecity.com/marina/finisterre/1228/jorjan/index.htm\" target=\"_blank\">Jordon Ultima Controller</a></b><br />Honda EU 3000 Generator
    LanduytG Guest
    hotdog
    I now have a bracket that makes it easier to install the Amsoil Dual remote bypass on any GM truck. It will clear the torsion bars and allow the filter system to be put any where on the inside of the frame rail.
    Greg
    Nov 2000
    Pensacola, FL
    I installed the Amsoil DR filter on my truck. The instructions that come with the filter are pretty good. I made a bracket that fastens to the frame without the need of drilling holes. Made it out of 1/4 inch aluminum and has two clamps that hold to the frame. The bracket that comes with the system bolts to this. I've got it mounted about 4' in back of the OEM filter. Have about 1200 miles on it since the install without any problems.
    Ed
    GMC 3500 D/A 4x4, SLT<br />Running Boards, Lucerix Mirrors, gauges,CB,Street Pilot III w/outside antenna, Jordan Brake Controller,U.S.Gear Exhaust Brake,Amsoil Air and Dual Remote Oil Filter,Rhino Bed Liner, Mud Flaps.<p><a href=\"http://www.picturetrail.com/Edmac\" target=\"_blank\">Pictures</a>
