I am trying to locate the complete text of the launch shudder tsb. I did a search but the old references on geocities are not there. Thanks
Launch Shudder on Acceleration (Install New One-Piece Propeller Shaft) #01-04-17-001B
1999-2002 Chevrolet and GMC K2500/3500 Extended Cab Long Box and Crew Cab Short Box Pickup Models With Automatic Transmission
This bulletin is being revised to add model information, remove procedure steps and change parts information. Please discard Corporate Bulletin Number 01-04-17-001A (Section 04 -- Driveline Axle).
Condition
Some customers may comment on a vibration during acceleration from 0-40 km/h (0-25 mph). This may also be referred to as launch shudder. This condition may be more noticeable when the vehicle is carrying cargo or is used for towing.
Correction
A new propeller shaft is available for service to correct this condition. This new propeller shaft is a one-piece design and will replace the current two-piece design.
Install a new one-piece propeller shaft on affected vehicles. Refer to the service procedure and the parts information listed below. Match the affected vehicle with the appropriate propeller shaft. Refer to the usage information below. This fix does not apply to the Chassis/Crew Cab Models (K35943).
1.Remove the propeller shaft assembly and the center bearing. Refer to the Propeller Shaft - Two Piece procedure in the Propeller Shaft sub-section of SI2000. For this bulletin, it is not necessary to mark the components for re-assembly.
Important
The center bearing support bracket (1) must be removed in order to provide enough clearance for installation of the one-piece propeller shaft. Avoid damaging the crossmember during removal of the center bracket. For proper clearance, no more than 13 mm (
- You may not post replies
- You may not edit your posts
Forum Rules
