I have my new engine installed, with a new oil cooler. I am running a dual remote Amsoil filter system. I have new aftermarket lines, looking at the cooler lines and lines to the remote filter, I am thinking I can eliminate two of the oil lines.
Can I run the oil through the dual filters and then through the coolers and back into the filter adapter, and then either block off the stock cooler line outlet and inlet (on the block) or run a loop from out to in? Or could I run a line from the block to the dual filters to the cooler and back into the block and either block off the filter inlet/outlet or put a loop on it? Any other ideas how this will work properly? I want to make sure I am not taking oil away from anywhere.
I would like to eliminate some hoses, (fewer to leak) and clean up the engine bay at the same time.
