Okay guys,
Comments welcome:
SUPERLIFT ANNOUNCES THE RELEASE OF THE REVOLUTIONARY TRUSPEED SPEED SIGNAL CALIBRATOR
WEST MONROE, LA - A speed sensor calibrator has finally arrived that addresses the needs of any computer-controlled vehicle running larger (or smaller) diameter tires: The Superlift TruSpeed speed sensor calibrator. The TruSpeed works with any electronic speedometer and hooks up in line with the speed sensor located on the transmission or transfer case of the vehicle. The TruSpeed alters the speed signal at its source, so speedometer reading, ABS function, and transmission shift points are all corrected to work with any non-stock tire diameter. A simple four-wire hookup is all it takes to install the TruSpeed, and comprehensive installation instructions make calibration an easy one-man operation. It not only corrects the speedometer reading to within 1 percent, it can be recalibrated an infinite number of times if future gear ratio and / or tire changes are made to the vehicle. In addition, the TruSpeed can be programmed for two different height settings for those who make seasonal tire changes or those who frequently run two different-height sets of tires on the vehicle (i.e. "street" and "show" tires). The TruSpeed will soon be available for all domestic and import cars, trucks, and vans equipped with an electronic speedometer. For more information, contact your nearest Superlift dealer or call the company's sales / tech line at 800/551-495
[img]smile.gif[/img]
BBugg<br />2002 GMC 2500HD D/A 4x4 ext.Cab SWB;<br />Garmin Streetpilot GPS; PIAA 80 Racing Lights; A.R.E. MX Truck Cap w/Walk-In Door; Kargo Master Cap mounted Rack; Luverne Stainless Nerf Bars; Warn Rio Grande Stainless Winch Mount; MileMarker 10,500 lb. Hydraulic Winch; TFI 45 gal.Tank w/Fast Flo Nozzle; XM Satellite Digital Tuner; Duramaximiser; Truck Vault bed storage system; Cobra 75-WX-ST CB Radio<p> <a href=\"http://www.PictureTrail.com/bbugg\" target=\"_blank\">http://www.PictureTrail.com/bbugg</a>
