Thought I'd give an update on my transmission issue since some had asked for one. Finally found time to take my truck back in for a closer look at my still slowly leaking transmission. This time went back to my purchasing dealer. They had previously recommended another dealer, James Woods in Denton, who they felt had more experience. Woods mechanics were the ones who couldn't seem to duplicate the problem.
Was really pleased with Ewing Pontiac/GMC in Plano. They pulled the transmission and did another dye test. Found small leaks around pump bolts. Replaced pump bolts and resealed convertor using copper crush washers. Also found small oil leak I didn't realize I had. Pulled flywheel and found small leak coming from around a bolt in the rear seal plate. The seal seemed okay. Replaced and re-torqued all bolts. Took this opportunity to go ahead and do my second fluid and filter change. I provided the filter and fluid and they were happy to replace at no charge. With convertor empty got all 12.7 quarts replaced with new Transynd so I am now 100%.
Service writer was very helpful. Not offended at all that I seemed to know as much about the problem as he did. Let me go back into the shop and talk directly with the transmission tech. Tech was also friendly and helpful. He called TAC, got specific info on the fix, and opened a case file for future reference if necessary. Let me inspect work before, during, and after.
Also got cracked windshield replaced with original GM glass while it was there.
So far so good. Couldn't be happier with the attitude and service approach at Ewing. Let's hope this does it. If not, I have a record established that will likely lead to a new tranny.
2002 GMC 2500HD D/A, Crew Cab, Short Bed, Pewter with Pewter SLT Leather, Westin Stainless Nerfs, Line-X Bed Liner, Fumoto Valve. Run GM Synthetic Diff, Chevron Delo 400, Amsoil air filter, Stanadyne Performance Formula and Allison/Castrol TranSynd.
