I changed mine myself and it really wasn't bad. I dropped the pan and cleaned it. Reinstalled with the same gasket. Put in 3 gal of TransD. Pulled the upper line from the cool and clamped a hose to it. Crawled out and had the wife crank it. Filled a gallon jug and reattached the line. Took all of an hour and some of that was cleanup due to not getting the truck shut off fast enough after the gallon I would recommend just doing it yourself and then you know if was done right. You are probably right, the dealer has probably never done a change. You need 4 gallons for the change if you want to really flush the converter. I also change the transfer case at the same time and it looked much darker than the Allison. Uses a little over 2 quarts too. 5 gallons should get everything with a little left over.
[ 10-09-2002: Message edited by: chuntag95 (Chris) ]</p>
02 2500HD LT Dmax/Alli CC 4x4 Lt Pewter, Tan in, Amsoil, transynd, Bilsteins, Amsoil Air Filt, JK 4\" Exht, RollnLock, Rhino Liner, Remote start, alarm, High Idle, SPA DG211, Pred, Mega, Fumoto, Remote oil bypass, XL Tranny cooler, XM, Cell kit
