Thread: Transmission drain plug
    Sep 2003
    Kalamazoo, Michigan
    Would like to add a drain plug to the transmission pan. Seem one that mounts to the side of the pan...........appears that about 1" of fluid would be left in the pan. Seems like a plug mounted in the bottom would be better. On the other hand, might be subject to damage. any thoughts? Where would one find a bottom mounted drain plug?
    2004 2500HD LT Duramax LLY+Allison 2WD Extended Cab SB
    Cooper LTX265/75R16 tires
    Email vernj4@juno.com
    Heartbeat Hauler Guest
    VERN,
    Although more expensive, you might just consider an aftermarket pan. They are usually a bit deeper, more fluid capacity, and they come with the drain plug installed between fins on the bottom. This allows for a more complete drain and shields the plug from damage.
    http://www.bmracing.com/
    http://www.mag-hytec.com/Transmission_pans.htm
    Just to name a couple.
    JP
    mhagie Guest
    B&M Deep pans come with a bottom mounted drain plug, add a drain plug kit to the side of pan about 1" up, it is tapped 1/8 pipe thread which fits most gauge kits temp sender.
    You kill two birds w/one stone extra fluid= cooler temps and the means to monitor same.
