I know GM doesn't recommend towing in fourth, but any of who do it on a regular basis? How many miles on vehicle? any problems?
95 excab K2500 354,000+miles
/>89 excab K1500 489,000<br />84 conv. van 225,000<br />97 Passat TDI 304,000<br />96 Passat TDI 178,000<br />98 Jetta TDI 165,000<br />All diesel
I routinely tow in 4th. No problems. Of course I have a 4.10 rear, but I've seen many others on this forum who use 4th as well.
\'98 Chevy Suburban 2500 4X4, 6.5TD, 94K, 4.10 gears<br />K&N air filter, 4\" Magnaflow Performance Exhaust (cat modified), Isspro gauges (boost, pyro and tranny), Bilsteins, remote FSD, Turbo-Master, Max-E-Tork ECM, HO injectors, Jordan controller, Keystone Cougar 304 BHS<br />GCW 17,800# (all 7 of us, but without the bikes).<br />tstadulis@aol.com
I tow with my 6.5L/4L80E in OD always, and I got 150,000 miles out of it before the OD planetary exploded...If you've got the power, use it.
Cheers
I have 220,000 miles on my 4L80E. I tow in OD all the time.
I always tow in overdrive with my truck unless it starts hunting between gears.Originally posted by farmerherb:
4L80E = tow in overdrive unless it starts hunting between gears
4L60E = never tow in overdrive
Carey
154,000 miles and still counting. Use 4th most all the time unless I need to pull it down to a lower gear in advance of an autoshift. I keep the converter locked above 35mph, with the "BD" "Torq-Loc" which keeps the fluid cooler, also gives me extra gears. ie; 1st, 2nd, 2nd(locked), 3rd, 3rd(locked), 4th, 4th(locked), Works great with 7 ranges.
Tom McCauley (DP Member #513)
The 95 trucks had a sticker on them saying to not tow in OD. I haven't seen one on the 96 and newer ones.
When I purchased my 96 -- 3 years ago I had to sign a form from the sales dept. not to tow in OD. Tried towing without OD an got lousey mileage. Went tyo OD with much better results. Except of course when engine starts hunting, then I downshift, 193.000 miles so far.
96 3/4 chevy with 6.5 diesel looking to upgrade to Duramax with allison tranny in 8months
That's an old wives tail brought forward from the 700r4 trans.
My hub odometer on the trailer has 87,000+ miles on it and all of that was in OD. That why I got rid of the 86 Sub and the 700r4.
1997 Chevy 2500 4x4, Intercooler, BD Computer, BD Exhaust Brake, BD Torque Lock, Propane Assisted from Trailer, Remote trans cooler, and More on my page http://mysite.verizon.net/vze54tx9
My other project.
http://mysite.verizon.net/vze54tx9/kayak
Tanker.
How do you get 2nd gear Tork-Loc? Do you have the DIY resistor installed that I've read about in the DP? I only get lock-up in 3rd and 4th with my Sub. I could use 2nd lock-up with my Tork-Loc and US Gear exhaust brake coming down some long mountain grades out West.
BTW, I tow in 4th all the time. I saw a maximum of 210 degrees transmission temp., the other day, coming up out of Bullhead City, AZ,. That's a 14 mile pull, up, what, an 8% grade? With 170K on the clock, I think that speaks well for the L80E.
Dick Wells
OD tow all the time 3:73 without problems, my tranny builder says no problem keep the fluid clean and cool and you won't have any problems.
Tim, 98GM K1500 6.5TD(L56/L65), Heath PCM,3.73 gear,4L80 tr,4" exh,Amz air filt&dual oil flts, Heath remote FSD, TDO-7 clone turbo, Heath fan clutch,mandrel crossover, pilar gage BST/EGT/TRN, remote elec fan tran cool,alum trn pan
