I'm not sure the air shocks if available will help your problem with the front end dropping when lifting your plow. My son has a 1990 K-3500 SRW with a "Boss" power-vee snow plow, (about as heavy as it gets) and his does go down some. He doesn't seem to have a problem with it. You may want to add more load adjustment to the torsion bars, but then again you don't want to mess up your front end alignment. [img]smile.gif[/img]
Tom McCauley (DP Member #513)
