RonnieJoe,
What data do you have which would support your suggestion that mist injection is a gimmick?
No one can argue the obvious benefits that an intercooler can provide. However, I understand there is data that demonstrates specific advantages when using chemical mist injection: They include:
1. Efficiency - leaner air fuel ratio can be utilized for normal operation.
2. An increase in air charge densities which provides horsepower increase.
3. Relatively low cost of initial investment.
4. The moisture injested by the engine also participates in the combustion process as a super-heated steam, increasing the duration of the pressurization of the cylinder.
Depending on boost levels, the results of these benefits produce:
a. Intake charge cooling - A water only system will lower IAT by at least 170*, Water/methanol will lower IAT temps at least 200*. Methanol acts as a fuel as well as cooling the intake charge in this application.
b. EGT reduction of 100* - 250* is common
c. 18-70 HP increases. Some folks say even more.
d. Increased air charge densities of 3-5 psi
I'm certainly no expert on the topic, but these results are routinely reported by the few, reputable folks who are continually testing, improving and marketing mist injection systems AND Cummins and PS guys who for some reason (maybe because they're running at higher boost levels?) have been more eager than us to adopt this technology. Simply go to their forums and see for yourself.
Clearly, there are certain disadvantages associated with mist injection; the most noteable is the need to lug water on your back (a real PITA). But air-to-air intercoolers aren't perfect either. They are much less efficient at reducing air charge temperatures than mist injection systems.
I say run both systems, if you've got the caaaash. I think the bottom line is that they're two different systems with their own advantages and disadvantages. We're all big boys here and therefore have the ability to analyze both systems to determine what might work best in our particular situation. To suggest that all of those who have gone before and continue to see results from mist injection have relied on a "gimmicky band-aid" is being a bit harsh IMHO.
FYI...I understand that Jim is preparing a feature article on mist injection which is supposed to be out in the next month or so. Can't wait.
BTW RJ, it isn't my intent to start something. Personally, I need to do one or the other so I'm just as anxious as you, I think, to see more test results.
\'98 Chevy Suburban 2500 4X4, 6.5TD, 94K, 4.10 gears<br />K&N air filter, 4\" Magnaflow Performance Exhaust (cat modified), Isspro gauges (boost, pyro and tranny), Bilsteins, remote FSD, Turbo-Master, Max-E-Tork ECM, HO injectors, Jordan controller, Keystone Cougar 304 BHS<br />GCW 17,800# (all 7 of us, but without the bikes).<br />tstadulis@aol.com
