I have been using the cross-drilled front brake rotors on my 95 for over 4 years. I did not noticed much better stopping, but seems to cool the rotors better. I do think its somewhat better than what I had. They do not show any wrappage and I'm on my 3rd set of pads. I only removed the outer rust-crust between pads, never had to have them turned, and they are still true. You have a completely better brake sytem than what we have on the older C-K units of the 90's. I think you should be fine with what you have. If they get hot, and wrap, then I'd replace them. [img]smile.gif[/img]
Tom McCauley (DP Member #513)
