Have a 3 axle car type pull trailer with brakes on two of the 3 axles. Brakes are the magnetic type. Typically pull the trailer with my dually. Dually has brake controler. When applying brakes (even slowly) trailer tires tend to lock up. Have tryed using the sensitivity switch on the controler, does not appear to help. Situation is usually worse with no load on the trailer than when heavily loaded. Had the magnets and all checked out at a trailer repair shop a while back. Noticed the problem a bit then and should have gone bck to them. Any ideas?
