Then you might not like the 465. 465 is a 4 speed. 1:1 top gear. Only three of which you use normally.
You could use first gear, high gears and big tires to get some OD effect, but the step between gears is large, and first gear in not synced i believe..
but built like a iron $hithouse, no doubt.
IF you don't mind the engine singing at high rpms, its great. Some of the best milage I got was 22 mpg on a 4.10 K20 with 235R75 tires..
1996 K1500 6.5, 1984 K5 6.2 Banks both \"Stock\" (tilting hand side-side like Sammy Davis in Cannonball Run)<br /><br />Got Boost?
