I have been troubleshooting my IP with a Tech 1A and have been getting not so good results.
My first read showed a TDC offset of -1.57.
After a TDC learn it showed -2.00 and set a code 88. I adjusted the IP to the drivers side and now I read a TDC ofset of 0.00 and codes 34 (stepper motor) and 88. I have tried the TDC offset learn several times and still come up with 0.00 and the same two codes.
I have heard that a Tech 1A may not work with a 94 truck with an updated 5521 pump.
I have a rebuilt JK pump ready to install, but am not sure if my Tech 1A will work with it?
Thanks,
Gerry
94 K3500 Dually 4x4, Avant 18:1, Girdled, ceramic coat pistons, Phaser gear drive, 98 cooling mods, PMD cooler, JK chip, JK 4" exhaust, Gauges
