Having problems getting 6.5 to start turns over about 30 times before firing Had checked at 3 different gm garages and cannot find problem New lift pump no holes in fuel lines new fuel filter no codes relating to pump - have codes 23-84-99 all are related to accelerator pedal position but gm says has no bearing on starting problem. glow plugs working properly. If anyone has a similar problem and has a annswer please let me know
I recommend reposting this on the 6.5L forum for maximum coverage.
- You may not post replies
- You may not edit your posts
Forum Rules
