Dr. Lee, I have a 1999 GMC Sub running a NP 246 auto 4wd t-case. Recently I had an accident with a car running up under the burb tearing out the d/s suspension, axel, and damaged the front IFS diff, d/s torsion bar and bar x-member.
Prior to this accident, I had no problems whatsoever with this t-case, now it leaks at both output shafts, and whines when activated.
Here is the question: Could towing this burb in gear do such damage to the t-case?
NOTE: GM's owners manual is very clear about not towing the burb with this t-case at all in gear.
