Wanted
One crossover for a Banks 6.2L turbo kit,for a 4X4.Interested in a used or new piece.
I ended up buying mine directly from Banks...I couldn't find a used one at the time. It's actually two pieces, so you'll need two part numbers.
The Banks pipe is actually quite small in diameter...if you have good fabrication skills, I'd recommend you make one yourself. The worst part is the way Banks snakes the pipe around under the front of the engine.....it would take some work.
Good luck!
- You may not post replies
- You may not edit your posts
Forum Rules
