I'm looking for the Banks turbocharger assembly from the 6.2 kits, this is mainly a T04B turbocharger. I'm really in need of just the exhaust housing, so the turbo can be a junker, thats really ok.
Anyone got one sitting on a shelf that needs a rebuild?
email:
awesomechevyman at yahoo.com
(just remove the "at" and spaces and replace with the appropriate symbol)
I've got a couple of exhaust housings setting around my place. Garrett T4, 1.10, .96, ?? A/R sizes all available. The only problem is that they are the T4 flange, I made an adapter, but is currently in use on my tractor...
Due to size, and bolt on fit, I need the Banks T04B exhaust housing, there are two of them.
I'm wanting this to swap out the housing on my ATS turbo, which looks almost identical to the one Banks used. But need a housing to swap on after the engine is running, to compare the two.
I have a bad feeling that the ATS turbo housing is a little restrictive, so it will have great spool up, but not so great on the top end, which is where my foot resides some times!
John,
If you don't have any luck here, Grape once mentioned a place called Majestic Turbo. Supposed to be a good place with lots of new and used parts.
Justin
- You may not post replies
- You may not edit your posts
Forum Rules
