I loose 1 or 2 quarts of coolant every 2-3 months. Oil tests negative for glycol. Top hose is not pressurized on startup. Recently replaced potmetal coolant fitting that goes into the thermastat housing. Never had a problem before I used Water Wetter. Any ideas? If I replaced the coolant and got rid of the Water Wetter would it help? I use the truck to tow a large trailer and don't want to have a problem on the road.
2001 Excursion 2WD V10 formerly owned 99 K2500 6.5TD Sub 4.10 8600 GVWR,Spearco Intercooler, JK Isspro guages,Hayden SD fan clutch, Racor 645 30 mic, clean cat, JK FSD cooler,JK Boost Ctrl,JK HL relay, Optimas, rblt trany & transfer case, B&M Tranny cooler w/fan,200k miles, Prodigy, 05 Jayco Eagle 308 FBS.
