Check out the Advance adaptors link it may give you the info you need on the bell housing.
The reason I went with a standard is because I like them and in 1993 they claimed that it got 5mpg over the auto -- which I think is true after comparing many mpg's from other trucks -- this truck gets GREAT MPG. Also I spend a lot of time in the bush and like the idea of push starting it if all else goes wrong.
Al
Original D.P. Member #750, 2009 Ext Cab LB 4x4 Duramax/Allison, Black, Linex, 1993 6.5 TD 4x4 reg cab LB, 5 speed, 1972 Pontiac Lemans, 94 cady De Ville
