John,
Thank you for the response to my posting. Yes, the p/u was purchased on eBay from a Utah auction firm. The body, chassis and drive train seem to be in very good condition, but the engine is problematic. I need a work truck and it will serve my purposes very well once the engine issues are resolved. I ordered a compression gage and adapter last night and I will report the compression data as soon as they are measured.
Some additional symptoms: The engine smokes heavily (blue smoke) on starting. The smoke clears approximately 2 to 3 minutes after starting. There is oil in the induction hose between the filter housing and the turbocharger. I will replace the CDR as soon as one can be purchased. The engine produces a "clicking" sound at idle. This noise either stops or is masked with higher engine speeds. Probing with a stethoscope didn't provide any definitive information, but there does seem to be a slight increase in the volume of the metallic clicking sound in the proximity of the No. 6 cylinder.
Besides servicing the fluids and filters, I've replaced the glow plugs which has made the starting much better.
