Bosch 6.5 TD Injectors
1 set (of 8) Bosch 6.5 Turbo Diesel injectors. Genuine Bosch nozzles. Rebuilt only 40,000 miles ago. I changed to Marine pump/injector set up. I had these checked by a very reputable Diesel shop after I removed them and all have good spray pattern, etc. $250.00
Bobbie Martin
1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
GEP Optimizer 6.53 Detroit Diesel Power
6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2ΒΌ" Crossover, Mann ProVent
HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
No PMD, APP, CDR, optical sensor or vacuum pump!
Author of The DB2 Conversion Guide
Click Here to Email Me
- You may not post replies
- You may not edit your posts
Forum Rules
