I have removed the intake manifold in order to remove the PMD so that I have a spare. I ordered a new driver which also came with a new short harness. While installing the new harness, I broke off one of the studs that stick out of the back of the injection pump. A red and black wire connect to these studs. The two connections are then covered by a boot.
I assume that will need to remove and replace the part that the studs protrude from. This component is held in by two T10 torx screws. I have removed these. There are two holes that look like they accept a special tool to unscrew the part. Am I on track so far?
Thank God for you veterans to keep us rookies out of hot water.
It's a 99' Suburban
