Tough call. At 200K miles the truck is a gamble all around. Unless you plan on just fixing things as they wear out and keep on driving it.
Purchased Rebuilt's have always been a gamble in my mind. Who knows what the core was treated like. Some might say they wouldn't rebuild it if something was out of spec but how far in spec was it??? All depends on the source of rebuild.
I can't say whats best for you. For that many miles truck if I felt lucky and was doing work myself I might try to find a used lower miles IP on ebay or other source then have a good qualified IP shop go through it clean, fix, calibrate as needed. I don't know actual $$ for IP refurb. Where I work we generally rebuild measuring equipment like this: The invoice is written repair equipment to A-1 condition cost not to exceed 50-70% (depending on equipment and costs) of new unit cost.
A repair shop is not going to want to warranty work unless they know parts source etc. Then might only warranty craftsmanship of repair???
At 200K you should also look at other things to replace that would be important with new IP. Timing chain, injectors glow plugs water pump while you are there.
The first 100K miles of a diesel's life they are relatively inexpensive to operate after that all bets are off. Used is all I can afford so its maintain and fix as I go.
On edit: Might want to get more input on what should be replaced at 200K. The above couple of items I would think are a minimum. But between that list and an all out rebuild might be needed. Depends on my wallet and how catastophic a failure is where or not I replace other parts and consider labor savings of while I am there thinking.
