I need some 6.5 injector lines to run on my 6.2 that I am putting 6.5 heads on.
PM me if you have any that you are willing to sell
'83 Blazer, DB2 built like 4911 by Accurate Diesel, 6.5 oil pump, 6.5 turbo injectors, 82 6.2 block, 6.5 heads, serpentine, gm-4 turbo with turbo master, timing gears, custom stud girdle, lower compression
Pics: http://s153.photobucket.com/albums/s205/kkarlson_photo/
Hello,
I Have Injector Lines from a 94 Suburban K2500. They are made for the DS-4 pump. Not sure which pump you are running. If it is a DB-2 then they will NOT work. If a DS-4 then they should. Let me know interested at Bdv@cdumail.com post "Injectors Lines" in subject please.
Brent
1994 Chevy Surb 4x4 2500 6.5 L Turbo Diesel 4.1 Diff. 145,000 bought used.
It is a DB2. I just got some from the diesel depot. Thanks anyways.
