Thread: 6.5 won't start
    Mar 2004
    Bowling Green Va
    Default 6.5 won't start
    I have a neighbor who has a 94 6.5 in a step van. It won't start unless you use(we used a rag soaked in gas, then held over the intake manifold) a boost. Then it will start and run as usual, anyone had a similar problem? I checked fuel pressure at the fuel filter, good. Help Please!
    95 excab K2500 354,000+miles
    />89 excab K1500 489,000<br />84 conv. van 225,000<br />97 Passat TDI 304,000<br />96 Passat TDI 178,000<br />98 Jetta TDI 165,000<br />All diesel
    Lubbock TX, USA
    Check the glow plugs!
    Sounds like it's not getting any glow, so the plugs either are not getting power or they're toast!
    May 2005
    SE Wisconsin
    X2 - glow plugs
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
