ART, Just a tire size change to 285/75/16 and your 3.73's will give you a final of 3.42+-
I wasn't intending on making a big change in tread width. I think increasing the cross section of the tire from 9.6" to 11.2" will probably have a pretty big adverse effect on MPG. Additionally I think it'll be much louder.Originally Posted by DA BIG ONE
If I kept the stock height I was planning on using a 245/70-17 tire.
If I went up I was thinking of using a 255/75-17. I think this brings me pretty close. Might not be down to 3.42's but definitely at least 3.55's. Increases the height of the tire from 30.46
Art Paltz
1999 Suburban K2500 6.5TD (stock)
2000 Undercover Dragster, 468 BBC, 7.74@173MPH, waiting on new 622 aluminum BBC to be finished.
1992 Tube Chassis Camaro, 468 BBC, 8.54@157MPH (SOLD)
1987 Buick Grand National, 11.8@114, pump gas (for sale)
1969 Camaro SS/RS 396-350HP, stock restoration, it never leaves the garage...
Art, I'm thinking closer to 45mph for od/lockup w/4.10's. I also think using cruse control locks converter too.Originally Posted by TurboDiverArt
Tire width does effect milage, but tread pattern plays bigger role the MT/R's I used made mpg suffer, the SilentArmor is more road friendly and quieter so not as bad.
Your vss is on the t-case along w/2 other speed sensors, 1 for the front drive shaft, 1 for the rear driveshaft. I just discovered the "vss" hack works a little while ago.
Hacking the speed signal from the vss to the vssb will correct the speedo only and leave the 3.73 shift/lockpoints you have now.
Hacking the vssb you modify speedo, shift/lockup to higher mph setting, abs, cruse control. TheDieselPage sells the book showing the hack of VSSB.
I used a commercial VSS re-calibrator to modify vss signal only.
Getting accurate on speedo calibration comes w/hack either way, especially if you measure tire diameter and use this measurement in re-cal.
Who's a good source now days for the gear sets?
Greg
Diesel Page Supporter
Greg Landuyt
Lubrication Specialist, LLC.
1-888-306 4255
greg@lubricationspecialist.com
http://www.lubricationspecialist.com
Good Day!
"I used a commercial VSS re-calibrator to modify vss signal only." Could you be more specific? Jim doesn't mind at all if we mention product names, as long as we're not hawking them.
Hacking the VSS signal looks like it would NOT be a resistor or pot situation - from a quick glance, that signal is a frequency that would have to be multiplied or divided to hack (clarification please).
Blessings!
(signature in previous post)
82 6.2NA K15 4X4 pickup, 4spd man w/ OD, 335K+ "In Rust We Trust" (parked)
95 6.5TD 2500 4X4 pickup, Gear Vendors Aux. OD, > ¼ million miles - gone
95 6.5TD 1500 4X4 3/4T Suburban, Kennedy exhaust, > ¼ million miles
93 6.5TD 3500 4X4 1T crew cab LB pickup, 230k miles
Ok, It is called and "electronic ratio adapter" (ERA) from ABBOTT ENTERPRISES, INC. Just use your divide ratio between changes match it the switch settings (micro-rockers) and your goos to go.Originally Posted by moondoggie
www.abbott-tach.com or www.atrol.com
I assume you put this in series? Meaning you cut the signal wire going from the VSS to the VSSB and put the ERA in the middle? That way the VSSB knows the actual speed as modified by the ERA but thinks the gearing is still stock?Originally Posted by DA BIG ONE
Art.
Art Paltz
ThatOriginally Posted by DA BIG ONE
Art Paltz
OK, reading into your post a little more.Originally Posted by DA BIG ONE
Assuming that from a calibration standpoint the 4.10 VSSB setting does not affect mileage in itself or general health/management of the engine and drive train. Would it make sense, or is it even possible, to set the VSSB to 4.10
Art Paltz
