Originally Posted by
93GMCSierra
just a couple of questions, I have a 5 sp manual trans the shifter was labeled
L 1 2 3 OD
However I can drive in OD at 23 mph with out lugging an even have some torque on acceleration an at 65 mph my tach is about 26-2700 RPM. When really pushing the truck I hit 90 mph at 4000 which is were it seems to have a rev limiter, which is good as I was not intending to blow the motor.
Now my questions are this, why do my RPM's seem alot higher then others with the same set up?
Oh an when I got the truck it had stock sized tires, 245/75/16 steel rims, now has 265/75/16's still steel rims.
My speedo has not been corrected however the difference between its mark an a traffic radar checker is at most 2 mph at 45 mph
What kind of gears do you have in the rear? It's either steep gears or your tach is off. 4000 RPM's seems pretty high. My engine has pretty much quit at 3500.
Art.
Art Paltz
1999 Suburban K2500 6.5TD (stock)
2000 Undercover Dragster, 468 BBC, 7.74@173MPH, waiting on new 622 aluminum BBC to be finished.
1992 Tube Chassis Camaro, 468 BBC, 8.54@157MPH (SOLD)
1987 Buick Grand National, 11.8@114, pump gas (for sale)
1969 Camaro SS/RS 396-350HP, stock restoration, it never leaves the garage...
