I have a 97 2500 4x4, 6.5L and 5spd manual. What can i do to improve its performance and fuel econmy. It is 100% stock right now. any suggestions?
You've come to the right place! Start reading the articles and forums. I'd recommend buying the book of 6.5TD articles - then you have everything in one place.
Good Day!
Ditto - buy all the back issues. One of the best investments I've ever made.
Start with getting air in & out - bigger exhaust etc. Kennedy Diesel, one of our advertisers, shows how to clean up the intake on his website, all it takes is your time & effort. I have his exhaust on my Sub, & highly recommend it.
Don't do anything else until you've got gauges - EGT & boost, minimum.
Blessings!
Use the search function and buy the books. By looking at the sigs of the other members, you can gage the amount of work that has been put into their rigs. My original engine died and I did all the work to my truck. I had to do the job right or shell out big$$$ for a newer rig. If you haven't read it already, read the "Fuel mileage poll by GMC Hauler" thread. I'm sure that the info will be very useful to you. Good luck with your 6.5L journey for more power.
-*og%rice*-
93 C3500 dually 6.5td. 18.7:1, Balanced, Coated, Underdriven, BD 4" exh, Turbomaster, 2 gage pillar + 3 gage dash, Dual electric fans, DB2 4911(maxxed out), NV4500, Propane, 97' cooling, Pre luber aux oiling, Phaser timing gears, hand made glow plug wiring harness 10ga. fluidampr damper, two pass FMIC, more to come..............
Read the articles in my signature for a good overview. Also, get the 6.5 book and read about the Power Project truck.
