Thread: General Tire Questions
    Nov 2003
    Edison, NJ
    Default General Tire Questions
    Hi All,
    I'm now looking for tires to put on my new H2 rims. Ideally I'd like to stick with the stock width and height. I little taller is OK but definitely not more than an inch. If I have to go a little wider I will but again, I really don
    Art Paltz
    1999 Suburban K2500 6.5TD (stock)
    2000 Undercover Dragster, 468 BBC, 7.74@173MPH, waiting on new 622 aluminum BBC to be finished.
    1992 Tube Chassis Camaro, 468 BBC, 8.54@157MPH (SOLD)
    1987 Buick Grand National, 11.8@114, pump gas (for sale)
    1969 Camaro SS/RS 396-350HP, stock restoration, it never leaves the garage...
    Apr 2004
    Palm Beach, Florida
    Default Tires
    The 80 psi is for "E" rated tires. The factory steel rims for a 2500 6.5 burb are riveted being stronger than welded.
    I suggest if you go w/D rated make sure it is rated for 3,000+ lbs @ 65psi, remember we are talking a 2500 burb here.
    Nov 2003
    Edison, NJ
    Quote Originally Posted by DA BIG ONE
    Thanks, I see that now. Seems all most of the tires that are 3000lbs are E rated.
    Art.
    Art Paltz
    Apr 2005
    Seattle, WA
    Default Handy Tire info
    Here is a really nice tire spec chart from the BFG website. (Its the address for the info and spec on BFG TA's)
    http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
    Gives you pretty much everything you'd want to know about actual tire sizes, rim fitment, both weight rating, and actual tire weight capacity - which changes some dependent on tire size. For example - there are some "D" rated tires that will bear the same weight as an "E" rated tire - depending on size. Don't know if you can say that these ratings would be exactly the same for other company's tires - its just that this is a nice quick education on tire info.
    \'95 \'Burb 2500 4WD, 3\" exhaust, Eagle Alloys, Heath Balance Flow and 21\" 9 blade fan plus driver cooling mods, Heath PMD Isolater, plus ISSPRO Pyro and boost gauges waiting to be installed - 199K miles and counting - Towing Moosenstein - the locked and loaded trail Jeepster Commando.
