Originally Posted by
GMDiesel
The SS? Coloer at least has the fins. I was thinking of an sscooler with an electric fan remotely mounted with a Kennedy harness. Where to mount it on a van?
First off, if the PMD is working, the old saying goes "if it ain't broke, don't fix."
But preventative measures and being prepared are also note worthy!
The 6.5TD Vans are a bit different from the trucks... You'll probably have to use your best judgement on where to mount the cooler, I'd recommend a Beta "FSD Cooler" (black sync green letters) and the extension harness with a New PMD. Pick a spot on the van that get's airflow that's not through the radiator.
GMDiesel
And can I leave the old FSD on the pump and just get another? How much are they and where is a good supplier?
Get another New PMD, this allows you to use your factory driver till it dies, then use your purchased one.
GMDiesel
I believe DSG has a stainless braided oil line kit with a new cooler for around $235, anyone have any experience with this?
The DSG kit isn't designed for Vans, only Trucks/Subs/Blazers/Tahoe, etc., you would do best to make your own lines. The steel braided lines are top notch though.
GMDiesel
Glow plugs and relays? I see a quick start plug on ebay and was wondering if this is the way to go? I don't know if the van has dual batteries which this seller says is required. Anything else that should be replaced in the glow plug arena?
How does it start now? Be carefull with Quickheat glowplugs especially off ebay where there will be no "support" for the product after the sale. The factory AC60's ain't bad, but don't start real great in really cold climate.
GMDiesel
Air Filter? K&N replacement? Will that be a worthwhile investment? Improve mileage?
Some here really like the K&N filters, they do offer more airflow, but at the sacrafice of air filtration, which is mainly seen in severely dusty areas (where I live). The foam air filters (unifoam for example) offer great air flow and superior dirt filtration. Is it worth it? Probably not, as compared to other upgrades (exhaust).
GMDiesel
Van will pull around 3500# so I want to make it reliable. Does anyone know what kind of mpg I can expect. It's a route business with a mix of stop and go and cruising driving.
Van should pull that no problem, your fuel economy will depend on how you drive.
GMDiesel
AC vents? Doesn't come out center vents strongly. Suggestions on repair?
Lastly, it's good to have some 6.5TD van owners here on the page. But, due to the fewer numbers of them produced, and that are in the hands of private owners (verses fleet) a little more information can be obtained in the factory manuals. Helm still has manuals for these vehicles, they're just like the factoy manuals. Try ebay, I see express van manuals on there frequently in sets of 3 books usually, should cover things like this.
I think there is a cabin filter, this could be the cause of low flow.
Enjoy the ride!
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
