Hello,
I am driving a 05' LLY. Ive added a BD Power Intimidator programer running on "Tow Performance" as i have not done anything with the intake and exhaust. Im worried about high EGT, and I dont 'need' that kind of horsepower. My main persuit is milage improvements. Does anyone have any info on what kind of improvements I would typically see (based on different driving habits I know this can change a lot, or terrain). Curious if i put a cold air intake and bigger exhaust, am I going to see any improvements?
With the Intimidator I saw a 1-1.5 MPG (Im talking US Gallons always) (Hand calculated) increase unloaded if you drive really conservative, on the highway 110-120km/hr. Was hoping to see more than that with the chip. Stock I was getting 14-15MPG highway. Now 15-17 and if I drive really slow 90km/hr in British Columbia I can see upwards of 17.5 maybe 18MPG if the wind was blowing the right direction.
If you go by the computer in the truck it says I am getting 24-28 MPG on the highway. I have found that this is not the case because all it is doing is lying to you about how much fuel your consuming. IE: If I burn the whole 90 litre tank, it says I used 70 litres. So do the math and yes, you have 24-28MPG. If you used 70 litres, not 90! Anyone else have this problem with the chip?
Also, if I am to do the exhaust, how much bigger is big enough? 4 or 5 inch? Any noticible advantage from 4-5?
THanks in advance!
T.
