I have a 86 k5 with 6.2 and i'm putting a order into summit on tuesday. Anyways I would like to order a few gauges and want to make sure they will work on my blazer!
Tach:
http://store.summitracing.com/partde...5&autoview=sku
Tach:
I would call to see if it works off of the Alt. This is how the Tach work on the diesels that come OEM on the newer 6.5
95C3500.Ext.Cab 97 Cooling mods. DSG Gear-1.95 TDCO. Bilstein Shocks. Firestone Air Bags. FSD Cooler. Banks EX System. Egt,Boost & IAT Gauges. JK High Flow/pop Injectors. Turbo-Master. Max-E 2.0. Water/Alky Injection. Amsoil Dual Bypass. Baldwin filter. aFe Air filter, Air box & Turbo Mods. Power Service Product. Large Duels 235/85-16. Tool Box\'s & truck, 8200 lbs.
I believe the tach on the newer 6.5's is driven from the ECM via the crank position sensor input????????
It's actually driven off the alternator too, just internal to the alternator.Originally Posted by robyn
The tach described above will likely work well with the 6.2, it's got a external sensor that straps on the outside of the alternator via the biggest hose clamp you can buy. I haven't tested it's accuracy, but they're supposed to be "close enough."
J
Here is the Pyrometer I'm looking at ordering to!
That's a nice gage, but....Originally Posted by Ebrown
Be sure to get a probe with a rating of 2000
Thanks for all the replys!
