Anyone have GM or AC/Delcom P/N for 1994 K2500 6.5TD vacump pump?
AC-Delco part #'s
215-113
Without RPO A/C MAN CONT(C60)
215-115
With RPO A/C MAN CONT(C60)
215-113
215-115
Thanks, hate to sound stupid but are you referring to with or without air conditioning?
The vacuum pump part #'s span several model years and applications. Some of the applications are less than specific (especially up to 1994). The reference to the MAN CONT is for manual control of front A/C, compared to front/rear, and auto A/C.
Check your RPO codes for C60. If you have that code, you need the 215-115. If not, you need the 215-113. The descriptions are somewhat foggy, but should be as stated. Verify your RPO code, and it should be correct.
I have C60, ordered one through local AC/Delco for $161. Thanks
