Thread: Speedo to 700r4 gasket/o-ring?
    Oct 2000
    Spokane, WA
    Question Speedo to 700r4 gasket/o-ring?
    Is there supposed to be some sort of gasket or o-ring where the speedo cable screws into a 700r4? Mine seems to bottom out the threads and it drips trans fluid. Thanks.
    Randy
    2006 GMC 2500HD Duramax Allison Crew
    Sep 2003
    Feeniks, Aridzona
    Quote Originally Posted by 78Chev
    Randy
    IIRC, there is an o-ring on the shaft in the trans, not on the cable. The whole assembly is held in with one bolt. Remove the bolt/clamp and the shaft and housing will come out.
    Lubbock TX, USA
    It's a seal, not really an -ring. It's accessable w/o taking out the speedo gear housing. All you need to do is remove the small c-clip holding in the seal, and have the new one handy, they're orange in color.
    J
    Oct 2000
    Spokane, WA
    Thanks - NAPA have such as seal?
