Results 1 to 11 of 11
Thread: Cooling upgrade questions on 92-93 trucks
    Oct 2003
    NW NJ
    I have purchased the 97 cooling upgrade kit for my 92 GMC Sierra and would like to know what modifications need to be done to the dual t-stat crossover and/or throddle bracket and cruse cable/bracket?
    Has anyone done this?
    Any pictures, details?
    Thanks...
    1992 GMC Sierra("2003 TDP Photo Contest Winner") 6.5L Turbo Diesel, 4L80E Auto, 4x4, 3" Body Lift, 33"x12.5"x16.5" Tires, Back Country Nerf Bars, Banks Stinger Kit, Banks Pillar Pod, Banks Boost, Pyro, Trans Gauges, Kennedy Quick Heats, Lube Specialist Oil Lines cooler kit,
    2001 GMC Sierra EC K2500 6.6L 4x4 Duramax-Allison Long Bed, Predator 40hp program.
    Dieselboy Guest
    I haven't put on my cruise control yet, but using some of MP's design work and a little of my own, I came up with this.
    All the pictures plus bracket templates are here: www.oliverdiesel.com/images/dualtstats/
    I think that Yukon6.2 has got a similar project going, so he might have more advice to offer.
    Dec 2002
    Cincinnati, OH
    taznj63, Refer back to your "Turbo?" post. I put some info there that my be helpful. TDP bracket only uses 1 piece of metal 4 bends.
    92 GMC std cab C2500, Kennedy high flow injectors,port matched, Banks exhaust & gauges, intercooler, 97 cooling, Turbo Master.A means for a Toy
    Dezman125 Guest
    Tazanj63
    I have just finished my cooling up grade.I used the patern from More Power for the outlet housing. I used the templets from Dieselboy for the supports. After i built everything,i added my own touches,I do have a few pic's i could e-mail you if interested.
    Some advice,measure everything twice,and bolt up everything befor you make final welds.At one point i thought i had it ready to weld up,and figered i better double check everything. Good thing because the throttle wouldn't open all the way
    Tommor i get to put the first miles on the truck
    Dieselboy
    Thanks for your help in getting me the drawings
    Oct 2003
    NW NJ
    Originally posted by Yukon 6.2:
    Tazanj63
    Dieselboy
    Thanks DieselBoy...
    Sure I would like some pics, a pic is worth a thousand words.
    send to jeffevans63@comcast.net
    Thanks again...
    Feb 2001
    Fort Worth, Texas, US
    How do guys with the 94-95 trucks get the front side of the thermostat housing to clear the mount for the idler pulley?????????
    Dieselboy Guest
    [QB...Thanks for your help in getting me the drawings [/QB]
    I'm glad they worked for you.
    I'm interested to see what modifications you made. I've already got another template setup for high idle and better access to the coolant bleed screw. I haven't put on a cruise feature yet, and want to see your ideas.
    Last I heard, JK ( http://www.kennedydiesel.com ) was offering complete 1997 hi-cap cooling kits for the 1992-93 6.5 equipped trucks. He is including the modified t-stat housing and bracket with the kit for the mechanical pumps.
    MP
    Dec 2002
    Cincinnati, OH
    The bracket design in the 1999 Feature articles & supplement will give access to the bleed screw and uses a portion of the old bracket so throttle and cruze can be used and be in the same location as b4.FYI
    No need to make separate brackets for each.
    john8662 Guest
    Grape,
    to clear the tensoner bracket you'll have to take off the alternator and then the bracket and do some grinding, here is what I did. (pics of the grinded spot).
    http://members.cox.net/acmdsl/coolin...ver/index.html
    Aug 2000
    Jacksonville, FL USA
    Here is the throtte cable bracket on our 95 DB2 equipped Suburban. Based on the template from the 2001 reprints, but with some changes. This bracket can be removed without removing the rad hose. Front cable is throttle, rear cable is cruise.
    Bobbie Martin
    1995 Chevrolet Suburban 1500 6.5 TD 2WD- DB2 mechanical fuel injection
    GEP Optimizer 6.53 Detroit Diesel Power
    6.53L, GEP Block & Heads, .020 over, ARP studs, DB2 Inj. pump, GM8 Turbo w/TurboMaster
    K47 Airbox with K&N filter, 3" mandrel bent exhaust, 2ΒΌ" Crossover, Mann ProVent
    HO Water Pump, Hayden "Truck Fan" Clutch, 21" 9 blade Duramax Fan
    No PMD, APP, CDR, optical sensor or vacuum pump!
    Author of The DB2 Conversion Guide
    Click Here to Email Me
