[CENTER][CENTER][B][FONT=Times New Roman]HONEYWELL LAUNCHES NEW GARRETT
I've seen this kit. It's a wastegated GT37 for LB7's using a T-3 mount. Very professionally done. No other kit on the market for Dmaxes is as complete and well made.
This would be an excellent choice for towing if your stock charger has failed.
Tuner of fast "diesel" powered trucks, www.McRatRacing.com
2005 GMC 2500HD "Casper" 11.77 @ 114.5 on #2. 674rwhp, 1380tq. EFILive "McRat" tuning, Mike L Suncoast, PPE Dual CP3's, HighTechTurbo "McRat" charger.
2004.5 GMC 3500 "Big Blue" 13.1 @ 103 on #2. PPE Tuned, Mike L Suncoast Trans.
2006 GMC 2500HD "Wendy" 13.9@96 on #2, PPE tuning, Mike L Suncoast trans.
I would like to point out though that their 440hp number needs a little explaining.
You will not get 140hp increase in a LB7 by just changing chargers. Tuning will be required.
440hp is a crankshaft reading.
This charger will most likely support over 550rwhp (rear wheel HP is about 20% less than crankshaft reading). Tuning only will net between 500-550.
So what does this all mean? When you run a moderate tune with this charger, it will survive at WOT when towing using 440hp.
With big tunes and short bursts of acceleration like drag racing or sled pulling, you can run more tuning and make much more power.
It is not a "full race" charger, and is not intended as such.
A stock Allison transmission will only handle about 325rwhp reliably (~390 crank HP), so you will not want to run a very big tune with this charger if you have not modified your transmission.
I just got all confused. What is in the LB7 now?Originally Posted by McRat
I have two LB7s with lots of miles. Would upgrading the turbo increase my likelihood of piston or ring wear - or is the boost level similar with improved volumetric efficiency? What could I expect from a driveability point of view?
- Previous owner of two 1994 6.5L K3500s, '01, '02, and '05 6.6L K2500s, '04 C4500, '06 K3500 dually, '06 K3500 SRW, '09 K3500HD SRW, '05 Denali
- Total GM diesel miles to date : ~950K
Has anyone installed one of these kits? Reactions?
