Something strange going on. Now that it’s cold I seem to have something going on with the ABS. It didn’t happen last winter so it’s something that is new. It only occurs in the first few brake applications. I don’t know if it has to do with it being cold and then going away once something warms up. Seems that when I go to apply the brakes the ABS activates. I can hear the ABS motor engage and the pulsing sound/feel of the brake application. I’m definitely not engaging them and I’m not on anything slippery, happens with light application. I did increase the tire size by 4% but I’d think this would only decrease the application of the ABS, not increase it and not only when cold. It also happened last night when I left work, cooler night. Only seems to happen in the beginning and not with every application. Seems after the first minute or two it never happens again. I checked the brake fluid level and it’s OK. I didn’t check the power steering fluid but the steering seems fine. I had initially thought air in the line but I can’t see how this would effect it. The truck does seem to stop and braking I don’t think is affected. It’s more annoying than anything else. When it happened last night I stomped on the brakes. They seemed normal the ABS continued to be engaged but the truck stopped well.
OK, here’s a little additional information from this morning. I tried a few things. Seems only to happen when turning to the right. I have not tried it at high speeds. I do notice that it happens about every time if I’m going straight at say 10-mph, slightly turn the wheel to the right and apply a light to moderate brake, the ABS will engage. If I apply the brake first and then turn to the right it doesn’t seem to happen or happens a lot less frequently and not as noticeable if at all. I was not able to reproduce it when turning to the left. The brakes do get a little hard when reproducing the problem and turning to the right but I’m not sure if this is just the ABS pulsing. I definitely seem to have stopping power but I might not have as much, like maybe the right front is not helping to stop the car. I’m sure I have brakes because if I didn’t I would have driven onto my neighbors lawns this morning. I’ll try to reproduce it this morning when I get to work to ensure it’s really going away once warm.
I’m thinking maybe the right front speed sensor? Maybe a loose/chafed wire? If the wire were grounding/shorting (chafed wire) on the right front would the ABS system “think” the wheel was stopped? I don’t know how the sensor works and what it would read if the sensor was bad or the wire was disconnected/shorting/grounding. Neither the brake light or ABS light comes on. I did notice about a month or so ago that the ABS light came on once for about 15 seconds and then when off. I think it was in the morning but I don’t remember the above problem happening. Since the light went out and the braking seemed fine I didn’t give it another thought. My first thought when I saw the light was that the fuse had blown but then it went out.
Any ideas? Anything to check?
Art.
